Praise for the "Mojo Tire Lever"
Postby billr » Tue Apr 19, 2016 12:12 pm
Almost 10K miles on the Michelin Pilot Road 2s and they are bald...
My local independent shop closed doors. Went to a few of the brand name dealers to get quotes for tires....
At least $300 for tires and another $100 to mount and balance...Off the Bike!!!
I'm frugal...okay...cheap... :D
I acknowledge the local shops need work, but come on...
Decided it was time to do my own tire change and I didn't really want to spoon on another set of tires (been there, done that...OUCH)...
Lots of internet research, decided on the Harbor Freight changer and a Mojo Tire lever.
Harbor Freight tire changer. $90 local.
Mojo Tire Bar and Blocks $139...
Shinko Podium 006 radials, 140/60 rear and 110/70 front. $160 shipped to my door.
After putting the tools together one evening, I changed the tires this weekend. Off the bike to back on took me about 2 hours total.
The Mojo Bar lived up to the "hype", easy to use, go slow and make sure to follow the "correct" video directions... :wink:
Like this one:https://www.youtube.com/watch?v=d_J5_sRRiAk
$400 bucks from a shop...I have about $300 invested in the tools I bought this time, plus the tires....so I'm a bit in the hole.
Will make all that back on the next tire change.
Long test ride on the Shinkos Monday. Turn in is a bit quicker, hold a line well. I didn't push, will wear them in a bit longer.
Varying reports on mileage from other riders, I'll keep track and update.
BillR
billr
Re: Praise for the "Mojo Tire Lever"
Postby DAVID THOMPSON » Tue Apr 19, 2016 5:10 pm
good deal
the last time i did tires it was a wrestling match and the tires won :smt023
Postby MZCountryRider » Wed Apr 20, 2016 8:56 am
I bought a used Coats 200 tire machine for $325 two years ago. Should have bought one long before...
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Postby ekirtz » Fri Apr 22, 2016 12:30 pm
Ooh! Good info. I will be checking this setup out. I've gotten "good" at changing tires over the years...by which I mean maybe 20% of the time I still pinch the tube and that usually my rims are so crappy that I don't mind an occasional skritchy scratchy.
This praise for the Mojo Lever has motivated me to post a little praise for the actron vacuum pump/brake bleeder...!
ekirtz
Users browsing this forum: No registered users and 52 guests
