Source for cables? Clutch cable about to go!
Postby DrGonzo » Tue May 10, 2016 12:24 pm
I sent an email to Motion Pro. We shall see. Any other sources for Silver Star cables?
DrGonzo
Re: Source for cables? Clutch cable about to go!
Postby MZCountryRider » Tue May 10, 2016 1:30 pm
Barnett Tool & Engineering makes custom cables as well. Basically, you'd send them your old cable and they'd duplicate it.
http://www.barnettclutches.com/service_center/default.aspx?cat_id=5
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Postby DAVID THOMPSON » Tue May 10, 2016 4:52 pm
EDIT see posts further down the page for more info
http://americandirtbike.com/
and the cure a hydraulic clutch but not cheap
http://americandirtbike.com/magura.htm
Postby DrGonzo » Sun May 15, 2016 1:31 pm
Any advice on how to replace the cable. It looks like I will have to remove the timing belt and so forth to access the cable at the engine?
DrGonzo
Postby MZCountryRider » Sun May 15, 2016 5:00 pm
You should just be able to remove the plastic plug(s) (with screwdriver slot in them) on the clutch case and unhook the lower end of the cable.
Charlie
'73 Guzzi Eldorado
'76 Guzzi I-Convert
MZCountryRider
Postby DAVID THOMPSON » Mon May 16, 2016 10:38 am
here
is link to pdf
viewtopic.php?f=26&t=4280
Postby DAVID THOMPSON » Mon May 16, 2016 11:39 am
also here
rotax clutch cable adj.pdf
(348.79 KiB) Downloaded 600 times
Postby DrGonzo » Mon May 16, 2016 11:43 am
Thanks guys. I did figure it out and removed the cable. Now sending it to Motion Pro for a new one.
DrGonzo
Return to 500 cc
Users browsing this forum: No registered users and 43 guests
