Mz 1000s starter teeth broken !
Postby silver MZ-1000s » Thu Jun 02, 2016 7:00 pm
Halo . Guys i need help ! Would anybody know where i can get a part for my Mz ? Looks like a starter shave of some teath inside of the engine . Would graham have that part or i have to cnc that here ?
silver MZ-1000s
Re: Mz 1000s starter teeth broken !
Postby MJ310 » Fri Jun 03, 2016 1:39 am
If Grahams don't have it you might struggle, from what I can see its called a vibration damper and the part number is 3543540005. Do you have a spare parts fiche for the MZ?
MJ310
Postby silver MZ-1000s » Fri Jun 03, 2016 7:27 am
Hi . Lets hope Graham will have it . I would hate to take other engine apart . I do have some options , but i rather buy that part new if possible .
silver MZ-1000s
Postby MJ310 » Fri Jun 03, 2016 10:33 am
Do you know what caused it or how it happened?
MJ310
Postby DAVID THOMPSON » Fri Jun 03, 2016 10:59 am
http://www.muz.de/ersatzteillisten.html
spare list
some times they call things a balance but in english where i live its called a slip clutch
looks like its Gaulded inside and did not slip when it should have if it has a fine nut and a cupped belleville washer
its a slip
the unit on the rt125 bikes does this and helps blow up the starter sprag clutch= $$$
https://en.wikipedia.org/wiki/Belleville_washer
its supposed to slip in both directions a bit when it does not slip things break
Postby silver MZ-1000s » Fri Jun 03, 2016 11:51 am
Halo . I have no idea for now what culd be a problem , i just know that since i got the bike it was making noise when you try to start the engine , sometimes would start without that noise , but most times there was a noise . Ibwas thinking that the battery i have in the bike is not strong enough to turn the engine , bike have 195 miles when i got it so i did not susspect anything wrong with it . Since i have other MZ that i ride , this one is just standing in the corner pf the garage and i start it to warrm it up on ocasion . Yesterday i was trying to wash it , i start the engine ( with the noise ) warm it up , shut down , wait fot the bike to cool down while i wash the other . Than i try to pull up to mu washing place . And this time i have rattling noise but no start . Called Graham in UK , they know the problem , just send one of those parts to Australia not long ago . Price is comparable with Aprilia sprung clutch so i dont think is that bad . MJ 310 thanks for the part number , i got some suspicions what was the problem but need to wait for the part and than i will investigate more , i will keep you guys posted , thanks !
silver MZ-1000s
Postby dandywarhol » Fri Jun 03, 2016 1:36 pm
You'll need to remove the missing teeth from the engine and oil system, drain the oil and change the filter before you restart the engine. It also might be worth glueing a magnet into the bottom of the casing to attract any shrapnel still in there and recheck after a few hundred miles
Whale oil beef hooked
dandywarhol
Postby silver MZ-1000s » Wed Jun 22, 2016 9:41 am
Part is on the way ,ETA 10 days . Cant wait !
silver MZ-1000s
Postby DAVID THOMPSON » Wed Jun 22, 2016 4:05 pm
after a large amount of cash has been sent :smt022
Postby silver MZ-1000s » Thu Jun 23, 2016 8:13 am
Well . Unfotunatly we dont have other parts source than Graham so we are kind of f.... I culd have that gear CNC by my friend for little more than i paid for the whole part , he would make five of those gears but i chose to go with original part . It was around 270 with shipping .
silver MZ-1000s
Postby Thorsten-aus-SO » Thu Jun 30, 2016 4:29 pm
Hello everyone.
These problem is well known and there is a thread in our German forum :http://mz1000.motomonster.de/viewtopic.php?f=8&t=443
Just in moment, a friend has the same problem with his 1000S. There are a few specialists in Germany.
Check out http://www.skbikes.de/ and http://www.mz-faber.de/. These are the best and the repair is not a problem. I gues spare parts can be shipped to ... (where am I ? US/UK)
Kind regards
Thorsten
Thorsten-aus-SO
Postby silver MZ-1000s » Sat Jul 02, 2016 1:59 pm
Hi . The part have arrived on monday . I have put everything together , and engine starts with one touch of starter button right now ! Wow . I cant find anything that would cost the damage , i check the selenoid , and the baterry was disconected for 3 weeks and no problems there , so i assume that since i have the noise when i try to start the bike almost every time since i got it with 195 miles on the clock , i assume i must have buy the bike with that damage ! I wanna thanks everybody for help getting that part and part number , thanks .
silver MZ-1000s
Postby MJ310 » Thu Jul 07, 2016 1:56 am
Glad you got it sorted, now just ride it.
MJ310
Postby silver MZ-1000s » Thu Jul 07, 2016 12:14 pm
Hi . After i fix it last week , i made decission to part with the silver one , since it was just sitting in the garage ! I trade it for 08 KTM RC8 with 3400 miles . I still have a black MZ 1000s so i would be aroud the forum !
silver MZ-1000s
Postby silver MZ-1000s » Thu Jul 07, 2016 12:20 pm
silver MZ-1000s
Return to 1000S
Users browsing this forum: No registered users and 116 guests
