Mastiff running rough.
Postby ericetz301 » Thu Jun 09, 2016 5:23 am
The problem showed up on a recent trip,
Although the bike started and ticks over and ran fine, but, after about an hour it started to play up, I could not get above
45-50 mph it would back fire and cut out if I tried, I changed the plug but this didn't improve things.( so, a very tedious, 100 + mile trip home ) :(
any advice would be appreciated.
cheers Eric.
p/s getting the carbs off looks like a big job.
ericetz301
Re: Mastiff running rough.
Postby manxie » Thu Jun 09, 2016 5:28 am
Hi Eric. I had a similar problem with a car many moons ago. I changed everything I could think of, it turned out the HT leads were breaking up? May be worth a look since you`ve already done the plug....just a thought? Good luck, Steve.
1998 1200 Bandit
1980 Yamaha XT250
1984 Yamaha Chappie 80cc :-)
manxie
Postby DAVID THOMPSON » Thu Jun 09, 2016 7:08 am
mine did this once turned out to be a wire falling off the coil the 12volt feed from the switch
Dave
Postby ericetz301 » Sun Jun 12, 2016 4:13 am
Thanks for the advice guy`s,
The electrics being the problem had`nt occurred to me, I`ll check them out, and getting to the HT coil etc. looks easier than getting to the carbs.
cheers Eric.
ericetz301
Postby lowgloss » Fri Jun 24, 2016 9:27 pm
Try adjusting the valves.
Intake valve tends to close up when the engine heats up.
lowgloss
Users browsing this forum: No registered users and 35 guests
