ignition light
ignition light
Postby andyj50 » Sun Feb 05, 2017 12:07 pm
ignition light does not go out when running indicating not charging any ideas
andyj50
Re: ignition light
Postby DAVID THOMPSON » Sun Feb 05, 2017 8:28 pm
which model bike
Re: ignition light
Postby andyj50 » Mon Feb 06, 2017 11:18 am
it is mz ts 150
andyj50
Re: ignition light
Postby DAVID THOMPSON » Mon Feb 06, 2017 12:36 pm
check battery water and brushes and all wiring from gen to battery clean battery post connections
Re: ignition light
Postby andyj50 » Sun Feb 19, 2017 5:57 am
done all that even changed the small wound coil all to no avail
andyj50
Re: ignition light
Postby DAVID THOMPSON » Sun Feb 19, 2017 1:10 pm
check that the charge lamp is a stock OEM bulb
some systems get upset if not the proper bulb
try placing a small high power magnet on the generator housing and pulling it away quickly
while its running
some times generators will loose there magnetism when setting for a long or even a short time
this may get it going it may not
one of those pickup sticks with a powerful magnet on it may do the job
Dave
clean the place the brushes run against also
Re: ignition light
Postby andyj50 » Sun Feb 26, 2017 9:05 am
will give that a go when I get time,cheers
andyj50
Re: ignition light
Postby Blurredman » Sun Feb 26, 2017 9:59 am
Double check the battery condition by putting it on a full charge (if you have a machine to do so). Check voltage of the battery with a volt-metre.
Charge light sometimes comes on if the idle is too low. The idle is best at 1200/1300rpm.
Is the light dim at low speed ? Does it go out at all at the higher rpm speeds?
Users browsing this forum: No registered users and 43 guests
