MZ ETZ251 battery + wiring
Postby alexxx » Mon Apr 03, 2017 3:41 pm
HI,
Just got an MZ ETZ251, opened the battery case to find a couple of extra wires that I am not sure about.
The main battery leads are easy to id but the other two (black/red and black/blue)..no idea what they should be connected to, any thoughts?
Can the 1991/92 MZ ETZ251 be started without a battery? it is the 12 volt version with (I think) electronic ignition
alexxx
Re: MZ ETZ251 battery + wiring
Postby Blurredman » Tue Apr 04, 2017 7:18 am
Those two wires should go to the indicator relay..
Postby alexxx » Tue Apr 04, 2017 10:14 am
Thanks, now I know I need to buy a flasher relay.
Do you know if these bikes should have a 9Ah battery.
Regards,
Alex
alexxx
Postby Skorpion » Tue Apr 04, 2017 1:04 pm
Hi alexxx,
The ETZ 251-301 came with a 5.5Ah battery.
The ETZ 250-300 came with a 9Ah battery.
I'm sure I've heard that a 9Ah battery will fit into a 251 you will just need to check the dimensions .
Skorpion
Postby alexxx » Tue Apr 04, 2017 3:10 pm
Thanks to everyone for such useful information
great wiring diagram too.
I wonder why the later bikes had a smaller Amp hour rating, the trend is usually for more.
Will it be ok to use a larger Ah battery? just thinking of old japanese bike where the indicators and lights would dim so much at tickover and at night..virtually nothing but a dim headlight at tickover.
Never had an MZ before so not sure what to expect.
alexxx
Postby DAVID THOMPSON » Tue Apr 04, 2017 6:37 pm
did you mean an A not a V
Postby Blurredman » Wed Apr 05, 2017 3:20 am
I use an 9ah battery in my '90 251. It fits, physically in the provided space and although the headlamp dims a little at idle, it's no way near as bad as a magneto system. It's noticable, but not dangerous.
Postby alexxx » Wed Apr 05, 2017 5:21 am
Thanks to all.
alexxx
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
