More Petcock
More Petcock
Postby sanddune51 » Mon May 01, 2017 2:07 pm
Being thoroughly fed up with having to remove the standard Skorpion fuel tap each time the fuel tank had to be removed, I made up a straightforward fitting to replace it.
I turned a piece of 2 inch 7075 Aluminium round bar in the lathe and then drilled the mounting holes.
Finished off by shaping using hand tools.
sanddune51
Re: More Petcock
Postby sanddune51 » Mon May 01, 2017 2:13 pm
It was quite a bit lighter than I anticipated, which was a bonus.
Compared to the original tap
Mark.
sanddune51
Re: More Petcock
Postby sanddune51 » Mon May 01, 2017 2:35 pm
Of course the above is now used in conjunction with a quick release coupling which weighs just 15 grams. All in all a worthwhile little job that should maintenance tasks just a bit less of a faff.
Fitted to tank.
Mark.
sanddune51
Re: More Petcock
Postby breakwellmz » Mon May 01, 2017 3:18 pm
NICE ONE!! 8)
Re: More Petcock
Postby dandywarhol » Tue May 02, 2017 2:52 pm
Neat us per usual Mark :smt038
Could you give a link to the coupling?
Whale oil beef hooked
dandywarhol
Re: More Petcock
Postby sanddune51 » Wed May 03, 2017 12:25 pm
Thanks Mate. The fuel coupling was purchased from Kayla at Projection components.
They seem to be widely available on the internet.
Mark.
sanddune51
Re: More Petcock
Postby DAVID THOMPSON » Wed May 03, 2017 3:29 pm
i need to do something like this but need a reserve as very few stations out in the country where i live ..and zero after 10pm
unless in town
Re: More Petcock
Postby Skorpion » Thu May 04, 2017 3:56 am
Beautiful job.
Though not sure why you cannot take the tank off without removing the fuel tap.
Never had a problem in the thirteen years that I had my Traveller.
Skorpion
Re: More Petcock
Postby DAVID THOMPSON » Thu May 04, 2017 10:59 am
i have seen 3 different petcocks on Travellers one is very long with a filter
the OEM tap on my Saxon Tour with the rotax is very long and makes taking the tank off a pain
Re: More Petcock
Postby Skorpion » Fri May 05, 2017 3:24 am
Don't know of three different fuel taps, mine was same as in sanddune51's photo.
I just needed to be careful lifting & replacing the tank, as the fuel tap rubbed against the wiring harness.
Skorpion
Users browsing this forum: Google [Bot] and 21 guests
