TS250/1 Idling Speed
Postby Daniel_I » Sun May 06, 2018 6:00 am
I have adjusted the idling/tick over speed to about 1600RPM, The spec. sheet suggests 850RPM. Is this realistic? Many thanks.
Daniel_I
Re: TS250/1 Idling Speed
Postby rightsideup » Fri Jun 01, 2018 11:08 am
Unrealistic I would say, mine doesn't really tick over at all unless it's set ridiculously high. I don't find it a problem as I'm not often stuck in traffic or waiting at lights.
'74 Ducati 750GT | '78 MZ TS250-1
In the high latitudes of Finland, in the parching heat of Africa, under the most different operating conditions these motor-cycles run to the satisfaction of their owners.
rightsideup
Postby Puffs » Sun Jun 03, 2018 3:46 am
With the pilot 2½ turn open & the bypass 3½ turn open, my 251 idles to my liking at around 1650 RPM. That's on the mechanical rev counter, which I'm not sure is very accurate. Haynes specify 1200 RPM for it.
Edit: this thread caused me to have a look at the idling of my ETZ251, which has a BVF 30 N 3-1. By closing the bypass a little further it does idle slower, and it can idle at around the 850 RPM you mention, in a stable fashion (doesn't miss a beat). But I don't really like it, the pick-up on the throttle is then sluggish, and most importantly: the entire engine vibrates up & down in the rubber. So that must load/bend the exhaust. I went back to about 1500 RPM.
Postby Blurredman » Thu Sep 27, 2018 4:56 am
All 2t MZ's are speced to idle at 1,200-1,300.
Mine idle around that nicely, Sometimes a little higher, perhaps 1,700 or even 2,000 in neutral but. In gear, 1,300 :lol: :lol:
I find that a lot of things change the idle, dependant on load of the engine. Even a slight gradient in a hill (or having the bike on the centre stand can change my idle speed quite drastically). Indicators, headlamp being on (you can definately feel the lights effecting the engine), even brake light can change it. In my opinion.
Postby DAVID THOMPSON » Thu Sep 27, 2018 7:56 am
back in 1965 to 1975 the fellows used to idle the 500cc /600cc bmw motors at very low speeds
all it did was starve the engine for oil and ruin the cranks
check what the factory says
Postby Puffs » Fri Sep 28, 2018 6:50 am
Yeah... but aren't those long stroke 4T boxer twins? You can probably make those almost go in hibernation, like the heartbeat of a bear in winter time.
Lubrication shouldn't really be a problem for a 2T, certainly not w/ pre-mix. As you're not riding, the cylinder should stay nice & warm, so that the petrol fraction should still evaporate & leave the oil fraction behind, to drip down through the ports towards the main (ball) bearings; similar for big end & small end.
But if you want to make idle that slow is another matter; just use your judgement. The 1200-1300 RPM quoted above seems more sensible.
Postby arny » Mon Jan 28, 2019 3:54 pm
The factory manual (for ETZ 250 though) does not specify idle speed at all. They describe a procedure where the idle is correctly set when certain engine behavior is achieved.
Arny
arny
Postby Daniel_I » Fri Mar 15, 2019 2:35 am
Puffs wrote:With the pilot 2½ turn open & the bypass 3½ turn open, my 251 idles to my liking at around 1650 RPM. That's on the mechanical rev counter, which I'm not sure is very accurate. Haynes specify 1200 RPM for it.
Many thanks.... got it down to about 1200-1300 and it runs nice
ley
Daniel_I
Postby Blurredman » Fri Mar 15, 2019 4:25 am
I think anything below 1200 and the transition between idle and throttle load is a little fluffy. 1,200 seems to be the lowest reasonable point where the throttle response is still crisp, rolling on. Perhaps as a way to prevent spark plug oil contamination.
Users browsing this forum: Google [Bot] and 10 guests
