Puffs wrote:.......see below as an example for an alternative I drove a couple of years with (+ shortened inlet skirt).
Puffs wrote:I can imagine one would use something like this:
or thinner, but on mine it is (and as far as I can see, has always been with this manifold) just metal on metal, with a good fit.
The original manifold has an M6 bolt on either side to clamp the carb's spigot, but the thick alu will not allow for much movement. So the fit will have to be good & hard, if you want to use that original manifold. But of course you don't have to, see below as an example for an alternative I drove a couple of years with (+ shortened inlet skirt).
I would use a high quality product like this one from my local bmw supplierPuffs wrote:Yeah, so? Radiator hose comes in exactly the right size, is resistant to petrol, reinforced, and very strong. Pray tell: what would you use for the flush spigot of the stock BVF?...
well donePuffs wrote: The reeds didn't come from any other bike, I made them for this reed valve, from aramide & epoxy. I made the entire thing, except for the re-purposed radiator hose and the 8 screws, those were made by someone else. I used it for some 4 years.
Users browsing this forum: No registered users and 131 guests
