Skorpion - sprocket carrier bearings.
Postby Hooperman999 » Tue May 15, 2018 2:57 am
I need to change the bearings in the sprocket carrier, which should be easy. However the longer one is seized in the bearing so trying to pull/lever it out using a bearing clams did not work, although that was successful with the shorter spacer on the other side. I have tried to knock the longer spacer out using a 17mm drift, but is burring up the narrow end of that spacer but not moving. Is this just a case of hitting it harder and harder or have I missed something?
I will buy another sprocket holder and spacers of anyone has spares.
Hooperman999
Re: Skorpion - sprocket carrier bearings.
Postby Hooperman999 » Mon Jul 02, 2018 8:28 am
Did you sort this? Having difficulty in getting the spacer to move sideways so as to be able to tap the first bearing out
Hooperman999
Users browsing this forum: Google [Bot] and 9 guests
