ETZ 250 side stand
ETZ 250 side stand
Postby akirasan » Thu Aug 23, 2018 2:25 am
The side stand o my250 points straight when it is down and is a bit unstable.
I saw a TS250 and the stand pointed further forward.
Did the change it for the ETZ?
It is fitted correctly I assume I will have to grind part of the bracket away.
akirasan
Re: ETZ 250 side stand
Postby Blurredman » Thu Aug 23, 2018 4:14 am
Sometimes the section that essentially becomes a spacer doesn't fit very squarely, and can often end up twisting sightly anti-clockwise, esspecially if you have a stand with return spring on.
1987 MZ ETZ300 - 40,000 miles
Postby akirasan » Thu Aug 23, 2018 7:24 am
The stand is as clockwise as it can go it is on the end of the bracket
akirasan
Postby Blurredman » Thu Aug 23, 2018 7:50 am
The stand might be, but is the braket?
You can also take a file to the 'trench' that runs under the swingarm to allow for extra adjustment.
Have you got a picture please?
Postby akirasan » Thu Aug 30, 2018 11:45 am
I have cut away part of the 'stop' to allow the stand to point further forward and painted it too.
The bike is a lot more stable
akirasan
Postby DAVID THOMPSON » Thu Aug 30, 2018 12:53 pm
as you own a bike you have to fine tune things to get it all correct
like.. my rt125 under the rear of the seat the wires for the turn lamps were routed wrong
the wires were so tight you could play a song on them like a guitar
mod to make it go faster are not my thing to do
but fixing things that cause it to fail are on my fix it list
Postby akirasan » Wed Dec 12, 2018 5:36 am
The stand i have must be a cheap copy as it is now bending along the flat part by the bracket.
any quality ones available?
Tis is a single spring
akirasan
Postby Blurredman » Wed Dec 12, 2018 6:13 am
The aftermarket ones are crap.
You must find an original.
Some parts I have found you must have original. Whether that be throttle clamps, inlet manifolds, side stands. Some of the quality is God-damn awful!
Postby Puffs » Wed Dec 12, 2018 8:48 am
Postby akirasan » Thu Dec 20, 2018 9:02 am
Luckily I know someone who has a cnc engineering business and he will re weld and reinforce it.
Hopefully it will work.
The cheap stand was fitted to work almost vertically so no issue bending but when I positioned it
correctly it could not take the 'weight' of an ETZ
akirasan
Postby alexxx » Tue Feb 05, 2019 8:08 am
Can anyone tell me the correct length for a 1991 MZ ETZ251 side stand please, the one fitted to my bike is way too short.
Regards
alexxx
Postby Puffs » Sat Feb 09, 2019 6:46 am
Sorry, haven't a clue. Can't you just make a block below it, to increase the length?
Postby Guesi » Mon Feb 11, 2019 1:21 am
There are 2 diffferent sidestands...
One for the 16 " rear wheel like ETZ 251 or TS 250
One for the 18" rear wheel like the ETZ 250.
As you have the ETZ 251, you should have the shorter one for 16" wheels. If yours is to short,someone had made it shorter .
Is your side stand positioned on the rear wheel or on the front footrest ?
Guesi Motorradteile
MZ spare parts
Postby Puffs » Mon Feb 11, 2019 6:21 am
Postby alexxx » Mon Mar 04, 2019 9:16 am
My bikes side stand is at the rear wheel and is too short,
I will measure it to see if it is 16 inches then make it the desired length, a quick and easy job :D
alexxx
