Burning oil
Burning oil
Postby tr500 » Sat Dec 29, 2018 10:45 am
Since changing oil and filter my Skorpion Sport has started smoking on starting up, it clears after a short while, but I am puzzled as to why. The usual problems are rings, valve guides, but these usually develope over a period of time. Any help or suggestions will be gratefully received.
tr500
Re: Burning oil
Postby DAVID THOMPSON » Sat Dec 29, 2018 6:00 pm
did you get toooo much in it..
Re: Burning oil
Postby Blurredman » Sat Dec 29, 2018 7:33 pm
What grade of oil were you using, and what are you now using?
And as David says: Didn't over-fill it, did you?
Re: Burning oil
Postby tr500 » Sun Dec 30, 2018 5:37 am
No, didn't overfill and 10/40 semi synthetic used.
After trawling through the Mz site I am wondering if it maybe coolant is causing the problem because on my last run out the bike was misfiring, but cleared after a while.
tr500
Re: Burning oil
Postby tr500 » Sun Dec 30, 2018 6:10 am
At first I thought I may have overfilled because it wasn't showing on the dipstick, so I drained off the oil and refilled to the correct amount and still not showing above the minimum mark and the reason for this ( I think ) is that a different front end has been fitted lowering the bike. The front end is off a Suzuki gsxr.
tr500
Re: Burning oil
Postby Puffs » Sun Dec 30, 2018 8:45 am
Re: Burning oil
Postby Blurredman » Mon Dec 31, 2018 3:27 am
I really should think you need to level the bike somehow then to take accurate oil level results. I find that if I use the manufacturer's stated guidlines, then sometimes I need to add a little more, sometimes as much as a pint, because the manufacturer's guidelines were to half way up the mark and not full.
What does the exhaust smell like?
Re: Burning oil
Postby Puffs » Mon Dec 31, 2018 6:10 am
Re: Burning oil
Postby tigcraft » Tue Jan 01, 2019 3:57 pm
Bit of a long shot but you could do with dropping the radiator pressure from the cooling system before the engine gets turned off to see if the cylinder draws coolant into it or not as the case maybe. If it’s better on the next startup then the only changes were coolant pressure entering the cylinder. Problem found!?
tigcraft
Users browsing this forum: No registered users and 48 guests
