MZ Skorpion sprocket carrier bearings
Postby Hooperman999 » Fri May 18, 2018 3:39 am
Having mega trouble getting the rear sprocket carrier bearings out. The long spacer is seized to the bearing. Any ideas? Anyone got a sprocket carrier for sale? - hooperman100@btinternet.com
Hooperman999
Re: MZ Skorpion sprocket carrier bearings
Postby droy » Fri May 18, 2018 8:49 am
assuming your using a drift to try to knock it aside and get to the bearing? you might need a bearing puller or heat it up(it will kill the bearing) and see if that loosens it up.
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Postby edfmaniac » Sat May 19, 2018 8:48 am
I have my old wheels and carrier but you should be able to get those bearings out with the right tools. Get a bigger hammer or run down to the local shop and have them pressed out. And while you are thinking about it, hose the thing down with penetrating oil if you haven't already. ;)
Postby joehenderson1 » Sat Jan 05, 2019 3:37 am
Hi, bit of a random one, but does anyone know where I can buy a sprocket carrier for a MZ Baghira 660? Preferably UK.
Cheers.
joehenderson1
Postby Dan-dridge » Sat Jan 05, 2019 4:54 am
Have you tried Grahams?
Dan-dridge
Postby joehenderson1 » Sat Jan 05, 2019 3:15 pm
I have mate but they’re saying it’s £100, is that normal price do you know?
Cheers for your reply
joehenderson1
Postby Dan-dridge » Sat Jan 05, 2019 6:17 pm
As i'm sure you know bud, 2nd hand spares are hard to come by & there aren't that many dealers that supply mz parts new or 2nd hand. Out of interest why do you need the whole sprocket carrier when it's usually the bearings that need replacing?
Dan-dridge
Users browsing this forum: Bing [Bot] and 151 guests
