Misleading multimeters
Postby Puffs » Sat Apr 27, 2019 5:39 am
This was a thread about digital multi-meters, when measuring the voltage at the battery, gave very fluctuating and confusing values.
That behaviour was diagnosed to be caused by the electro magnetic pulses generated by the (original) ignition, without using and R sparkplug or R spark plug cap to limit the current in the HT lead.
Re: Misleading multimeters
Postby dave47 » Sat Apr 27, 2019 4:48 pm
Some years ago I had a similar fault on my TS150(6 volt), with wildly fluctuating voltage and brief spikes which maxed out the multimeter. It turned out to be a faulty spark plug cap, and was cured by a replacement.
dave47
Postby Blurredman » Sun Apr 28, 2019 5:43 pm
Glad you got it fixed!
Postby dave47 » Sun Apr 28, 2019 6:28 pm
Yes, you have done well to keep an MZ regulator working, although I am not sure that 13.5 V will be enough to keep the battery charged.
If the EM field from the coil and leads can generate high voltage in the leads of a multimeter, is there not a danger that it will do the same in the bikes own wiring, in particular wires leading to semiconductors.
dave47
Postby DAVID THOMPSON » Sun Apr 28, 2019 9:10 pm
i have found the new testers to be a pain
i have several high power hf radio transmitters on my property that relay amateur radio messages
the new testers do not want to work correct so i use a meter made the year before i was born
to get the job done
the new stuff gets overloaded very easy
dave wd8cyv
Postby dave47 » Wed May 01, 2019 6:01 am
That is clearly the answer
dave47
Postby DAVID THOMPSON » Mon Aug 26, 2019 10:48 am
i have a antenna tuning box for my ham radio antennas
there are 3 am broadcasters on towers less than 1 mile from my house 1050 1230 and 1450
to check my antennas with it i have to wait till the high power station (5000 watts)
drops to its night time power of 163 watts at night
and the multi meters also settle down
DAVE
Postby DAVID THOMPSON » Sat Oct 02, 2021 10:23 pm
things have improved here also the 1450 am radio station moved its transmitter
about 10 miles north of me I have to listen to it on its FM translator at 98.1 as it is now hard to hear it at night on am
it plays oldies rock which i like
so
I can now use some of my test gear in the day time
Postby dave47 » Sun Oct 03, 2021 6:58 am
@david thompson. Here in UK they are trying to get us all on DAB or online radio, only a matter of time before they switch off FM. One reason I stick to my old Android 8 phone is most of the newer ones have the FM radio function disabled.
@puffs. Thanks for the update, some don't bother. But I still prefer 9Ah and my HC Cargo 130675.
dave47
Postby DAVID THOMPSON » Sun Oct 03, 2021 7:23 pm
store owners here are mad ..the newspapers are all closing and there using commercial radio and TV
to promote store sales ( much more expensive )
so doing away with the radio broadcasters is a bad deal
for local radio and the people need to see where to buy things
also some stations are doing local news on radio it had gone away for a while
the grocery stores sponsor the local news reports
and all so the local USA style football Friday or sat night
high school games
its all changing several free 3 or 4 page local paper sheets report news and advertisements
and appear on counter tops in restaurants and service stations
Users browsing this forum: Google [Bot] and 14 guests
