Continuation - 1974 TS 250 - More riding-Need tuning advice
Postby neomuzzi » Sun Aug 26, 2018 10:28 pm
Hi.
Finally decided to take the MZ TS250 out for a longer than a 2-3 mile cruise around the neighborhood. The knocking issue has not been solved, but so far it doesn't seem critical. At least not at the moment.
I went on a 20 mile or so ride in the back roads / hills of the area I live in and I have to say this bike is quite fun to ride. It was super stable and though I am not one for the riding position, it was a very enjoyable ride. Big power gap from 2nd to 3rd given probably too large a gap in gearing.
I definitely could use a bit of performance tuning. I don't have a tach, but this bike seems to run out of steam and need to be shifted at a pretty low RPM. Seems like the powerband is more low end torquey, but there has to be room for more.
Wondering if there are some standard mods. Pipe, ignition timing, new or ported barrel? Are there low hanging fruit or is it simply not worth it? I see a couple of cool MZ racing sites, so it seems some folks tune these bikes for performance. I did some searching on the forum but didn't find anything in the time I thought reasonable to search.
Thanks,
NM!
neomuzzi
Re: Continuation - 1974 TS 250 - More riding-Need tuning adv
Postby parrbd » Sun Aug 26, 2018 10:54 pm
Docoke the exhaust.
parrbd
Postby neomuzzi » Mon Aug 27, 2018 10:19 pm
Thanks. Will take a look. Bike only has 200 miles on it as far as I know. Almost feels like timing to me. The carb seems big enough to support more RPM, so exhaust it could be.
I see some cool looking expansion chamber type of exhausts, but I don't speeka duh German so hard to find one for sale. If anyone reading this knows of a place specifically to get performance related parts for the TS250, please do speak up.
My first thought was to go down a tooth or two on the front sprocket. But more HP would be a better solution.
thx.
neomuzzi
Postby Blurredman » Tue Aug 28, 2018 2:33 am
Is the bike actually revving out, ??
Or is it just pinking, like- hitting a wall? Every gear? What speed are you able to get up to in top when this happens?
I would not bother with the expansion exhaust system. The MZ's have expansion chambers, they are just neatly packaged up in the silencer and from my experience and those of others, are not superior in any way to the original exhaust systems.
Postby Andy_C » Wed Aug 29, 2018 4:07 pm
As suggested I would de coke the silencer, I would also check that the timing is set corectly, also check that yu have no exhaust leaks - in my experience a leaking exhaust system can make these bikes run badly.
Strongly advise against buying one of the expansion chambers unless you are any good with a welder - I bought one very cheaply just to try it.
As standard the chamber is way too short for the sort of revs that a standard MZ does, and it robs the engine of bottom end torque and pushes everything higher up the rev range giving you a very narrow power band.
I modified the chamber by cutting the chamber in 2 and welding in a long "belly" section, the pipe now performs as well as the standard pipe in my opinion - it just sounds a lot better, and the engine seems to rev a bit more freely and feels a bit livelier.
I'll post up a picture sometime.
Andy_C
Postby Andy_C » Sat Oct 13, 2018 1:16 pm
Here is a pic of my ETZ with the modified chamber on it.
Basically a 11" section welded in between the cones of the readily available chamber that pops up everywhere.
Without the welded in section you only have useable power abouve about 5000 RPM with the belly section inserted power delivery feels pretty much like it does with the standard system.
I like it because it does make the bike feel livelier as well as making it look a bit different !
Modified chamber
Andy_C
Postby Puffs » Mon Oct 15, 2018 6:37 am
Postby neomuzzi » Wed May 29, 2019 7:25 pm
Hey y'all. Coming back to this. Picking it back up essentially.
Went for a nice ride today after spending the last couple of days getting the bike to start easy and idle well.
Seems fine, but it also seems like the the electrical systems are weak such that unless the bike is warm and the battery is fully charged, it tends to want to stall due to misfires caused by lack of spark. Not exactly sure there, but it gets worse when a blinker is on or the headlight is on, so that is the clue I am working with.
Back to the power thing. The bike seems to make it to about 20 MPH in first gear, but then just holds there like it has some sort of governor on it. It just sort of maxes out. 2nd gear is near 37-38 MPH, but the same "run out of steam" behavior. I can keep the throttle wide open and it just drives along. If I shift, I am back on power, but assuming that 3rd would do the same once it reaches that same RPM range. Unfortunately I don't have a tach.
The bike has 200 original miles on it since 1974, so I doubt he pipe needs cleaning. Carb and Air filter are in great shape and recently cleaned.
Is that just the nature of the bike? Does the porting, exhaust, Carb, and airbox kind of give a hard limit to max RPM and power in each gear.
Thanks again!
neomuzzi
Postby DAVID THOMPSON » Wed May 29, 2019 9:25 pm
tired points spring
had a 72 750 bmw it had set for years like 18 it would run ok
but not much above 3000 rpm it was a dog
changed the points which changed out the spring and the point stopped floating
age had killed the spring tension so the points worked but floated at speed
Postby neomuzzi » Wed May 29, 2019 11:20 pm
Dave,
That seems reasonable. It is a good possible explanation for why the bike is nice and torquey and accelerates nicely but then just stops accelerating and holds constant with so signs of stress. Shift and I'm back in the power...
Any preferred vendor for those parts? UK? Germany?
What is amazing about this bike is its stability and yet agility. It is like I feel more comfortable on it than on other bikes I have ridden like a Yamaha R3. In some ways the bike has an "on rails" feel.
Keep you posted.
Thanks,
MG
neomuzzi
Postby Blurredman » Thu May 30, 2019 2:37 am
I've had 3 spark plugs go on my MZ's. And how do I know the telltale signs? The bike mis-fires and eventually dies with indicators and/or lights on.
Give it a try- Yes- I know it sounds silly..!
The electrics take quite a bit of power from the engine, you can feel the difference riding in the day compared to riding at night with the lights, I think..
Those speeds would seem to me to be pretty much end of the line for those given gears.. If the 5 speed bike maxes out at around 75-85, then I'm pretty sure a 4 speed would be the same- The fourth gear being pretty much an overdrive and only really of use on the motorway or dual carriageway. Top gear around town is best in third. You just won't have oomph enough to use 4th unless you're doing at least 45 and it's flat.
Postby Puffs » Thu May 30, 2019 5:34 am
Postby neomuzzi » Thu May 30, 2019 9:27 am
Thanks all. I'll investigate those areas.
This is the listing for the bike when I bought it.
https://www.mecum.com/lots/LJ0617-284074/1974-mz-ts250/
I read it as 174 miles. Am I wrong?
Thx!
neomuzzi
Postby Puffs » Thu May 30, 2019 11:26 am
Postby Andy_C » Fri May 31, 2019 3:21 pm
I agree with Puffs - that is a really tidy bike.
Stick with it you will get it to run properly.
Andy_C
Users browsing this forum: No registered users and 95 guests
