How long...
How long...
Postby Puffs » Fri Jun 14, 2019 10:36 am
Re: How long...
Postby DAVID THOMPSON » Fri Jun 14, 2019 3:52 pm
lot of the life is how much current is used and at what voltage
the term to look at is Dwell how long the points are closed and the coil is powered
and how is the quality of the capacitor
link is for 12volt systems
http://www.geocities.ws/loudgpz/GPZheiModForPoints.html
http://www.gofastforless.com/
have fun reading
Re: How long...
Postby Andy_C » Sat Jun 15, 2019 1:46 am
A few variables here I would say - has the little felt pad being been kept lubricated.
If not then in theory the heel of the points might wear quicker.
Are you using electronic ignition? if you are the current through the points would be greatly reduced so the points would last longer.
I would say, given how much points cost, any doubt just replace them, but then again the old addage applies "if it aint broke dont fix it"
Andy_C
Re: How long...
Postby Guesi » Sat Jun 15, 2019 2:21 am
And at last it depends on which contact breaker you use:
-"Normal " original
-Original with "Pertinax" material
-Reproduction
Guesi Motorradteile
MZ spare parts
Re: How long...
Postby Puffs » Sat Jun 15, 2019 6:32 am
Re: How long...
Postby Blurredman » Mon Jun 17, 2019 2:02 am
I've only replaced it on the MZ once, and that was because one of the contacts on the points fell off one day. The only discernable difference that made to running was a wavey idle.
I have replaced points on my car once too.
Re: How long...
Postby Guesi » Mon Jun 17, 2019 6:55 am
Lets make it simple: The contact brakers last as long as they last.
If I should make a "hit-parade" of the parts:
1.Pertinax
2. Normal Originals
3. Reproduction.
The exact time or mileage depends on so many circumstances that it is impossible to give an exact answer ...
Guesi Motorradteile
MZ spare parts
Re: How long...
Postby Puffs » Tue Jun 18, 2019 3:37 am
Re: How long...
Postby Blurredman » Tue Jun 18, 2019 4:06 am
I would say anywhere between 15-30 really..
My last set lasted 20k if they were the original set. And my current set I have on now is at the 10k mark almost.
So, I think it's possible to get to 33k..
Re: How long...
Postby Guesi » Wed Jun 19, 2019 12:16 am
Sorry, but I don´t understand the use of such a discussion.
There are so many influences to the lifetime of a contact breaker that you cannot predict its lifetime.
If it is worn out, I change it. No matter how long it lasted...
Or change to an electronic ignition :-)
We all can be lucky if this is one of our biggest problems with our MZ bikes :-)
Guesi Motorradteile
MZ spare parts
Re: How long...
Postby Blurredman » Wed Jun 19, 2019 2:08 am
Not in my case.
Re: How long...
Postby Puffs » Wed Jun 19, 2019 4:29 am
Users browsing this forum: No registered users and 107 guests
