ETZ 250 Oil consumption
Postby Andy_C » Sat Jun 15, 2019 1:49 am
Planning a 200 + mile round trip on my ETZ in the next week or so, just wondering roughly how many miles I can expect to get out of a full tank of oil.
Should I take a top up bottle with me?
Andy_C
Re: ETZ 250 Oil consumption
Postby Puffs » Sat Jun 15, 2019 5:57 am
Yes, always.
But I believe they specify 1:50 mixing ratio for the Mikuni pump (how accurate that is I don't know, and with the pump also responding to throttle position it should also depend on how you ride). Say use 1:40, so with a litre of oil you get 40 litres of fuel, good for about 800km or 500 miles.
Postby dave47 » Sat Jun 15, 2019 4:51 pm
The operating instructions for the MZ oil pump states that the tank capacity is approx 1.3 litres, and that the range per oil tank capacity is "about 1300 km (depends on speed and riding conditions)", ie 1 litre per 1000 Km. This seems a suspiciously round figure!
I get more than 500 miles per litre, so you would not normally need a spare bottle for a 200 mile trip.
dave47
Postby Blurredman » Mon Jun 17, 2019 2:00 am
I imagine the pump and the reservoir would do around 700-800 miles. It's like 1.3litres?
I do pre-mix so it's hard for me to discern how much the pump would take. But I use 500ml per tank (however miles that ends up being, normally at least 200 miles).
But yes, as Puffs says: always take a small bottle.. just incase the petrol station you end up at is card only/non kiosk! I would hate to be one of those people who need fuel, but only buy their two stroke oil at the petrol station when they need it.. :shock:
1987 MZ ETZ300 - 40,000 miles
Postby parrbd » Mon Jun 17, 2019 8:21 am
On a few occasions I have been unable to buy two stoke oil and have used multigrade oil to get me to somewhere that had 2T oil (sometimes 100's of km). Never had any problems but I would not use it on a regular basis.
parrbd
Postby Guesi » Mon Jun 17, 2019 2:51 pm
Blurredman wrote:I imagine the pump and the reservoir would do around 700-800 miles. It's like 1.3litres?
500 ml per tank is about 1: 35 mixture.
That is far to much oil...
And, no , it is not true that the more oil you put in the better it is for the engine....
Guesi Motorradteile
MZ spare parts
Postby Blurredman » Tue Jun 18, 2019 2:14 am
30:1, 33:1, 35:1. I don't measure. At whatever point I get to a petrol station after getting into reserve I put the pint in.
I actually didn't say that more oil is better for an engine. Although now you bring that up it is very sore topic that gets brought up again and again and again. I have read documentation that says both oil is good and less is good. I don't particularly care- I just put in 30(ish) to 1 and ride the damn things.
The manuals may say use 50:1 but I want evidence that a german/european ridden MZ that has done.. let's say 60k miles on 50:1 without going beyond 1st oversize piston or main bearings.
:-D
Postby dave47 » Tue Jun 18, 2019 3:18 am
Just recently topped up the oil tank on my etz 250 after 499 miles. It took less than 1 litre , but was very full to start with and was half way down the window at the end. I don't normally leave it any where near that long, and wouldn't recommend it. A top up after every 2 fills of the petrol tank is a reasonable rule of thumb, imho.
dave47
Postby Puffs » Tue Jun 18, 2019 4:02 am
Yes Dave, a litre for a little over 500 mi sounds about right, for the oil pump.
On manual pré-mixing ratio's, adding more oil than required will not really help in lubrication, but if it's good oil that doesn't plug the exhaust & deposit huge amounts of carbon on & in the piston, it won't harm either. It might give some ignition issues. I've seen ratio's down to 1:20 specified (not MZ), aimed at ensuring reliability under difficult conditions. Personally I never went richer than 1:30 with a fully synth under race conditions, but normally used 1:35. The Jawa I also have to pré-mix (still using 1:32 semi synth), but that has cast iron barrels.
Carbon deposits can be an issue with (multigrade) 4T engine oil. Of course it's infinitely better than no oil at all, but using that should be avoided, IMO.
Postby parrbd » Wed Jun 19, 2019 8:23 am
I ran my TZ350's on 15:1 R30 and Shell 115/145. They always performed very well.
parrbd
Postby Andy_C » Sun Jun 23, 2019 2:49 am
Completed my trip - around 210 miles, plenty of 2t left in the tank.
Fuel consumption was around 50MPG which seems reasonable to me.
No issues with the running of the bike, in fact the harder I rode it, the better it seemed to go !!
I do have comfort issues - see new thread I have started.
Andy_C
