Etz251 no spark
Etz251 no spark
Postby jackotom » Mon Jul 08, 2019 4:05 am
Hi, my Mz etz 251 has been laid up for a long time
And now wont start, they seems to be no spark and the coil is getting hot
The bike ran fine a while ago.
Can anyone help.
Thanks dave.
jackotom
Re: Etz251 no spark
Postby Blurredman » Mon Jul 08, 2019 4:29 am
Seems to be no spark? there is either no spark or spark, surely?
Electronic ignition or contact breakers?
8) 8) 8)
Re: Etz251 no spark
Postby Puffs » Mon Jul 08, 2019 6:36 am
If your coil is getting hot it's constantly being charged, because for instance your points are corroded shut. Or something else is wrong. I think the advice is to check your ignition.
On the up side: the battery seems to work.
Re: Etz251 no spark
Postby jackotom » Mon Jul 08, 2019 7:17 am
Hi,took engine case of and the electronic ignition
was very corroded.
I cleaned it up best I could but no joy
Can these be repaired or can you still buy new ones.
Thanks dave.
jackotom
Re: Etz251 no spark
Postby Puffs » Mon Jul 08, 2019 7:23 am
Hi Dave,
pics would help.
Yes, you can buy anything for these bikes, see for instance viewtopic.php?f=5&t=9257
Re: Etz251 no spark
Postby jackotom » Mon Jul 08, 2019 9:17 am
Hi, cannot get picture to load?
Does anyone know how to remove all of the electronic ignition.
I wanted to see it had corrosion behind it.
Thanks Dave.
jackotom
Re: Etz251 no spark
Postby Andy_C » Tue Jul 09, 2019 9:59 am
Sounds like the electronic box or sensor is fried if the coil is getitng hot as it is continuously passing current.
Could understand if it was points stuck closed.
I had an ETZ 301 and that had electronic ignition - the sennsor was easy enough to remove as if memory serves it was obvious which screws held the sensor in.
Good luck.
Andy_C
Re: Etz251 no spark
Postby jackotom » Thu Jul 11, 2019 3:38 pm
Just an update, put plug in and it did not spark but when put back in bike I kicked
The engine over a few times and nothing happened
But when I turned the ignition of it backfired
And a oily mixture splatted on back of my house.
Does anyone know what could be wrong
Thanks.
jackotom
Re: Etz251 no spark
Postby Blurredman » Fri Jul 12, 2019 2:50 am
Take the spark plug out
Then turn the ignition on. if it sparks when the ignition is turned on, I think the black box is blown, likewise when turning the ignition off.
I have done this myself by mis-wiring the system before now. :evil:
Re: Etz251 no spark
Postby Puffs » Fri Jul 12, 2019 3:29 am
Re: Etz251 no spark
Postby jackotom » Sun Jul 14, 2019 1:53 pm
Pic of mz electrics.
jackotom
Re: Etz251 no spark
Postby Blurredman » Mon Jul 15, 2019 2:20 am
From which ocean did you pick that out of? :lol: :P :P
Nah I joke- but seriously- I had the same ignition that I blew- Did you try as I suggested? :)
Re: Etz251 no spark
Postby Puffs » Mon Jul 15, 2019 5:38 am
Re: Etz251 no spark
Postby jackotom » Mon Jul 15, 2019 1:57 pm
Hi,thanks for all your help.
I did remove the generator cover and cleaned it out, it was a bit rusty, I think I need to strip the generator and get any corrosion of the parts.
I have some new brushes and the part the brushes fit into(sorry don't know the name)
I don't know were to connect a mutil tester to test things as I cannot find my Haynes manual!
jackotom
Users browsing this forum: No registered users and 64 guests
