MZ 125 sm won’t even bump start
Postby JDsm125 » Sat Jul 20, 2019 9:46 am
Hey everyone.
My brother bought a mz125sm last night. There’s a list of issues longer than my arm. The main one is we haven’t been able to even get it running. How many safety cut offs does this thing have? All so where abouts are they? I’m quite savey when it comes to small single cylinders but this thing has me stumped. The starter motor isn’t engaging but the motor itself performs as it should, correct voltage etc. Later on this afternoon I’ll whip the side of the case off and poke my head inside. It has a vapour dash that looks cool but is pants. It’s got totally the wrong carburettor on it.
Basically how can I at least bump start it?
JDsm125
Re: MZ 125 sm won’t even bump start
Postby DAVID THOMPSON » Sat Jul 20, 2019 2:37 pm
the right side case has a spring and ball bearing that sets the oil pressure
look at shop manual before you dig
and a proper carb is a must and proper adjusted
the death of one of these bikes is some one wanting to make it go faster
which turns it into a parts bike
the factory had it going good they just forgot if ts not 400cc or bigger its a moped
Dave
finish your info in your profile and where your located
some one close may say hello and help
Postby baroquenride » Sat Aug 03, 2019 10:31 am
Yup, curious where you're located as I've got one too and perhaps I could help if you're close by.
baroquenride
Postby DAVID THOMPSON » Sat Aug 03, 2019 11:22 am
the part of his profile he did complete says he is in the UK
