by Puffs » Fri Oct 04, 2019 9:43 am
Puffs on Mon Jan 06, 2025 8:02 am, edited 3 times in total.
by DAVID THOMPSON » Fri Oct 04, 2019 8:31 pm
problems like this can be caused by bad solder also
- Moderator
by Puffs » Sat Oct 05, 2019 4:18 am
Puffs on Mon Jan 06, 2025 8:02 am, edited 2 times in total.
by Puffs » Thu Oct 10, 2019 5:37 am
by dave47 » Fri Oct 11, 2019 3:50 am
It definitely shouldnt be rigidly mounted. I replaced mine with an electronic one years ago, but as far as I remember it was fixed on the right side with a rubber "shock absorber" similar to that at the bottom of the rectifier. At the left side it was in a foam rubber sleeve.
Edit: It is part no. 30-34.037 Fastening rubber for regulator cut-out.
dave47
by Puffs » Fri Oct 11, 2019 5:06 am
by parrbd » Fri Oct 11, 2019 5:43 am
Yes that part rotted away on my ETZ250. I squirted a bunch of silicone around that end an let it set. So far, so good. Regulator still works and keeps the original 1985 battery charged.
parrbd
by Puffs » Fri Oct 11, 2019 6:25 am
Puffs on Mon Jan 06, 2025 8:03 am, edited 2 times in total.
by parrbd » Sat Oct 12, 2019 7:57 am
Yes the Battery life has amazed me. I have changed quite a few batteries in other bikes over the same period. The battery supplied with the ETZ when I bought it was a Yuasa standard lead acid battery. Twenty plus years ago I came out to ride it to work but the battery was flat. So I pushed it into the back of the shed. There it stayed until a few years ago. When I pulled it out to recommission it I noticed that the headlight and ignition had been left on all that time. The battery was about quarter full. I topped it up with tap water and put it on the charger. It held charge, the bike started and has been working fine ever since. I know it does not make sense.
parrbd
by Puffs » Sat Oct 12, 2019 11:20 am
Users browsing this forum: No registered users and 71 guests
