Etz 250 removing clutch cover casing
Postby tigcraft » Mon Dec 16, 2019 2:48 pm
im just trying to get access to the crank oil seal on this side but I can’t get the side cover off any more than 5mm. The thing is stuck around the clutch frontal area somewhere as the rear of the casing has more movement. Any ideas?
tigcraft
Re: Etz 250 removing clutch cover casing
Postby dave47 » Mon Dec 16, 2019 3:19 pm
Have you removed the nut/tacho drive from the end of the crankshaft? Its easily overlooked.
dave47
Postby tigcraft » Mon Dec 16, 2019 3:35 pm
Yes, the 22mm nut with the spiral drive on the end is off, so is the giant circlip and the circular plate with the three screws. The clutch cable assembly is also off. Also off is the oil pump which didn’t need to be, the kick start is still on but that is meant to be left intact. I don’t want to use force on the casing by prying for the obvious reason
tigcraft
Postby Puffs » Tue Dec 17, 2019 4:54 am
I also vaguely remember having had that same problem... But not the solution.
The clutch assy is stuck on something. Take off everything you can (including clutch mounting sleeve & adjustment plate). Look through the clutch sleeve hole, maybe the arm the cable connects to catches onto something? Does it help to rotate the worm gear? The kick & oil pump can stay, the gear shift lever should go.
Good luck.
Postby dave47 » Tue Dec 17, 2019 5:12 am
Beats me! Maybe the bearing is seized on the shaft, try tapping the inner race. Its unlikely, I admit, but what else is there?
dave47
Postby tigcraft » Tue Dec 17, 2019 6:17 am
dave47 wrote:Beats me! Maybe the bearing is seized on the shaft, try tapping the inner race. Its unlikely, I admit, but what else is there?
There is a bearing on view from the casing front Does that mean the bearing is supposed to break loose or does it stay with the other sub assembly behind. If it does not and it’s seized on then that’s the answer?
tigcraft
Postby dave47 » Tue Dec 17, 2019 9:49 am
The entire clutch actuation mech, including the bearing normally stays in the cover when it is removed. I have taken off a few covers over the years and this has always been the case. The bearing usually slides off easy. I don't know if it is possible to remove the cover and leave the assembly on the shaft. I am not a mechanic and am unable to say how you should proceed, but good luck with it.
dave47
Postby tigcraft » Tue Dec 17, 2019 10:26 am
dave47 wrote:The entire clutch actuation mech, including the bearing normally stays in the cover when it is removed. I have taken off a few covers over the years and this has always been the case. The bearing usually slides off easy. I don't know if it is possible to remove the cover and leave the assembly on the shaft. I am not a mechanic and am unable to say how you should proceed, but good luck with it.
That’s it I think. The bearing is locked solid and probably where I get my 5mm of movement from. I’ll shock it to death!! Thanks Dave for that. Eric
tigcraft
Postby dave47 » Tue Dec 17, 2019 10:52 am
I've just checked an old engine and I don't think it is possible to leave the assembly on the shaft. I believe they must come off with the cover.
dave47
Postby Puffs » Wed Dec 18, 2019 3:10 am
Yes, I think Dave is right. I forgot, it's been a while since I did that...
Haynes is not very clear on it in the dismantling section, but have a look at reassembly, sec 33.13, P65, ftp://blurredmanswebsite.ddns.net/Vehic ... es/065.jpg
Postby Blurredman » Wed Dec 18, 2019 3:47 am
Have you done all the steps as in this video?
https://www.youtube.com/watch?v=6ptXHE2i0x0
4:08 onwards...
1987 MZ ETZ300 - 40,000 miles
Postby tigcraft » Wed Dec 18, 2019 3:35 pm
Yes it was the bearing!! And video watched! It was seized on the shaft so I ‘air chiseled it a rude awakening’ !! It flew off now I just need to make a clutch extractor!!
tigcraft
Postby dave47 » Thu Dec 19, 2019 10:47 am
Excellent. The replacement bearing is C3 type, most of the rest are C4. The £10 MZ clutch pullers are alright, but if you can make your own better still. Just don't use a universal puller as they can distort the clutch (apparently).
dave47
Users browsing this forum: No registered users and 59 guests
