Brake light issues found. Now need parts.... Help?
Postby Eomund » Sat Apr 04, 2020 4:48 pm
Hey all. So after an exorbitant amount of reading, studying, tracing wires and testing stuff I have since found my issue I think. And it's all due to 1 missing wire and an incorrect light housing.
After a deep deep study of the schematic, I found out I was majorly over complicating everything. The brake wire literally comes directly off the coil with no inbetween. And the brake switches are actually ground interrupts. From what I could find, the light housing seems to be from an old suzuki, and a newer one at that. The light and brake in that light share a ground. Where the brakes need their own ground from how the switches seem to work. So I just need to run a wire from the coil, and get a housing that allows for 2 separate lights. So the brakes can be grounded separately.
I have tested this on my multimeter so I'm near certain it's correct. But if I do have something wrong. Please please let me know.
And if I am correct, where the hell can I get the right kinda light housing. I'm not sure what to search for and so far coming up goose egg.
Thanks!
Eomund
Re: Brake light issues found. Now need parts.... Help?
Postby Eomund » Sat Apr 04, 2020 6:45 pm
If it helps, here is what it should have come with from the start:
https://imgur.com/a/e0bVOpJ
Eomund
Postby Guesi » Sun Apr 05, 2020 12:14 am
Here is the right housing:
https://www.guesi-motorradteile.de/inde ... 4/c/_/_/?_
and the complete taillight with original lens:
https://www.guesi-motorradteile.de/inde ... 1/c/_/_/?_
Guesi Motorradteile
MZ spare parts
Postby Eomund » Sun Apr 05, 2020 12:35 am
Guesi wrote:Here is the right housing:
Holy shit I love you. I don't speak a lick of German. But I'll see what the total cost will be tomorrow
Eomund
Postby Blurredman » Mon Apr 06, 2020 9:47 am
But Unless I'm mistaken.. you have the US import version of the lamp that ALL USA Mz's seem to have.. the round type is what europeans have..
It does look suzuki ish however. What are the markings on the lens? Presumably it was changed to be 'DOT approved'...
You can tell the USA imported ones in the below link. They have the same lamps as you!
https://www.google.co.uk/search?q=mz+ts250+1974+usa&complete=0&hl=en&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjU3YXNhdToAhXdTBUIHbnNBtEQ_AUoAnoECAsQBA&biw=1280&bih=884
Question...
Are they single or bilux bulb capable ??
Postby Eomund » Mon Apr 06, 2020 12:43 pm
Blurredman wrote:But Unless I'm mistaken.. you have the US import version of the lamp that ALL USA Mz's seem to have.. the round type is what europeans have..
Question...
Well, the housing is bilux capable. But the switches literally aren't. Because they work off of a ground switch. So unless something was swapped back to european spec in the bikes life, the original lights had to have had 2 bulbs. Not duplex (The US name for it).
So for now I need a 2 light setup. I've made one that will work. And I will order one of the german ones when I can afford it. So I have something that works.
Eomund
Postby Blurredman » Tue Apr 07, 2020 4:46 am
I saw your thread. They look like typical trailer tail lamps. I'd say it's handy you can have indicators in red too! :lol: :lol:
Users browsing this forum: No registered users and 59 guests
