breakwellmz wrote:This sort of thing? -
Puffs wrote:Right - pics or it didn't happen...
'not fast enough to feel like you aren't pushing at all at legal limits'??????????? Even my 251 does naughty (and I don't mean within the city limits)...
Puffs wrote:Thanks for those pics!
Yes, surely a modern sportsbike like the street triple has the ratio of the gears closer, and consequently a much taller 1st. The XTZ660 was by origin a trails bike, which had wider gear ratios to cope with difficult circumstances. Close-ratio gearbox vs wide-ratio, and I suppose MZ took the engine un-modified. And of course the triples (both 675 & 765) are substantially more powerful than the single.
The miracles of 3d printing!
I'd put a F mudguard, without it, 1 wet patch and your visor is dirty. It might also be a legal obligation.
Radiator fans: are you sure you wan to have those off?
For making a good seat you need stiff (closed cell) foam, and properly shaped, and that's a problem. If you have suitable foam, maybe shaping it with a steel brush fitted in a stationary drill might work? Or use thin layers?
A bathroom scale, first F then R, should be OK, but for accuracy you should lift the other wheel by the same amount as the scale does, so that the bike is horizontal. Piece of wood, tile, ...
On your weight savings, 33lbs is a good start, but at 154kg dry it is still not spectacularly light (for the 58HP/58Nm engine).
Users browsing this forum: No registered users and 118 guests
