Skorpion: engine starter does not turn after 1 year storage
Postby WaiNYC » Tue Apr 28, 2020 5:10 pm
The bike has been in storage for one year. It is not starting now. Battery is OK, fuel line is OK. When the Start button is pressed, there is one "click" sound coming from right behind the battery, but the starter does not turn. And somehow, the N indicator is not lit even when gear is in neutral, but all other indicators are OK.
The engine last worked one year ago.
Any idea where it fails?
WaiNYC
Re: Skorpion: engine starter does not turn after 1 year stor
Postby Blurredman » Wed Apr 29, 2020 2:03 am
Do you need to pull the clutch to allow it to start, normally?
1987 MZ ETZ300 - 38,000 miles
Postby breakwellmz » Wed Apr 29, 2020 3:26 am
Neutral light switches stick i had to replace my recently.
I would be inclined to remove the starter motor to see if it has seized thru lack of use and if it spins up away from the engine, the click you hear is the starter solenoid.
Postby Puffs » Wed Apr 29, 2020 4:08 am
Postby WaiNYC » Sun May 10, 2020 6:02 pm
@Blurredman, @breakwellmz, @Puffs, @Dave Thompson... Thanks very mucch guys. The problem was indeed bad connection with the starter motor. The bike starts right up w no problem now.
WaiNYC
Postby breakwellmz » Mon May 11, 2020 10:34 am
Glad to hear it, sorry i didn`t think of suggesting it! :oops:
Enjoy!
Users browsing this forum: No registered users and 79 guests
