Puffs wrote:On the cooling of the 660 I can't say much (other than that it would surprise me if Yamaha hadn't sorted that out properly), but on the suspension issue: good to hear you're reducing the stroke to be more similar to what the R6 shock wants. The R6's track record in the SuperSports class suggests they must be doing something right.
On the forks: best make sure F & R are compatible (in both stroke & damping), otherwise it might turn out to ride a bit like a camel.
I am sure that the cooling system works fine, but because it has such variance it runs richer than is ideal.
The 2006 R6 shock with the 2000 GSXR1000 linkage fits really well. Some slight sanding of the linkage to make it fit onto the frame end, but not too bad. Once I get the mill in I will clean it up a little (not that anyone is looking at i
In order to size the dogbones correctly I started with measuring the stock shock and linkage height from the swingarm to the frame with the wheel off the ground, no load. I then installed the new linkage and the R6 shock, but didn't install dogbones. I put the rear wheel up on blocks of wood until I got the same measurement from the frame to the swingarm as the stock shock. I think measured the length the dogbones would need to be to give me that unloaded height. It came to 145MM. I put a new hole in the GSXR linkage and installed them.
I am now getting about 1.5" of sag with me on it. Almost perfect from the spring that came on the R6 shock. I have ridden around several miles, starting with the shock set at full soft, then going five clicks up on all three adjusters. It is so much more compliant and comfortable, and, even though I haven't ridden it very hard yet, feels very controlled. Makes the forks seem harsh though. For an current cost of about 75 bucks, this seems like a steal in terms of performance upgrade.
As for my forks plan, I think my plan right now is to just let the stock forks ride until I get the shock and FCR completely sorted. No need to start on another big project while the other two aren't completed. I am currently looking at doing a 1999-2001 R6 front end swap. I have found reports online of it basically bolting on with a DRZ-400 steering stem bearing kit. I have not measured anything to confirm that though. That generation of R6 forks is still right side up (looks wise I prefer that) and are supposedly fairly nice cartridge forks. Going the cartridge inserts into the OEM forks is tempting, but it would also be nice to go to a fork that so many people have made so many things for. Finding replacement parts and the like would be much easier going to a large OEM.
