TS125 head nuts torque
Postby spooky » Fri Oct 16, 2020 9:28 am
What should the cylinder head nuts be torqued down to ? :D
RE classic 500, 1951 Terrot etd, 1970 Gilera Autostrada, Vespa T5 and the Black Pig !
spooky
Re: TS125 head nuts torque
Postby dave47 » Fri Oct 16, 2020 11:49 am
According to the mz manual, 1.8Kg m (13lb ft).
The Haynes manual says 30lb ft but is certainly wrong!
dave47
Postby spooky » Fri Oct 16, 2020 1:44 pm
thanks, haven`t got a manual yet, only had the bike 5 years....
spooky
Postby DAVID THOMPSON » Fri Oct 16, 2020 6:21 pm
Haynes little book of fibs and lies bites again the one for my Nissan truck went in the trash
when i sold it
Postby Gerryman Ts125 » Sat Oct 24, 2020 4:01 pm
It's 20fp (only four 10mm nuts and washers, but clean their mounting surface with something to remove all deposits) if I remember :? Of course it is Run it for two periods of twenty minutes (with a 15 minute cool down time between) on quarter throttle (about 2000 Rpm if you have a working counter fitted) Then let it cool down for one hour (unless its drivable) Or 150 miles (approximately 240 Kilometers)then retorque.
P. S. And I have a well thumbed version of a Billy Haynes manual. For the Mz Ts 125-150. :D
Gerryman Ts125
Postby Puffs » Sun Oct 25, 2020 5:39 am
Postby Gerryman Ts125 » Tue Oct 27, 2020 5:42 pm
Puffs wrote:To avoid translation issues I had a look in the 'original' TS125 manual on Miraculis:
and in the English manual MZ published:
Now 1,8 kpm = 1.8 kgm = 17.7 Nm = 13.0 ftlbs.
Finally, always torque head nuts cold. These long studs are made of a steel alloy, which has (or may have) a different thermal expansion coefficient as the alu from the barrel & head, which is likely to expand more. The studs are elastic, but the tension in them increases with temperature.
Its like getting a quote for most things, get more than one (viewpoint) quote. Or read a `how to do it` book on them.
Gerryman Ts125
Postby Puffs » Wed Oct 28, 2020 7:37 am
Users browsing this forum: No registered users and 73 guests
