Skorpion front axle removal
Postby buell1965 » Thu Oct 22, 2020 7:35 am
Hi fellas , 660 skorpion front wheel axle removal . I have loosened the 2 allen head pinch bolts on left fork leg and not sure what is next and wanted to check before I proceed.
buell1965
Re: Skorpion front axle removal .
Postby DAVID THOMPSON » Thu Oct 22, 2020 11:37 am
it is screwed in has threaded end
it is some times hard to get back in on install
make sure wheel is off the ground when putting it back
wiggle top of wheel going back in
axle has threads nut is made into bottom of fork leg
Postby buell1965 » Thu Oct 22, 2020 11:58 am
Your awesome dave :D
buell1965
Postby buell1965 » Thu Oct 22, 2020 2:16 pm
just getting home and thank you , i was worried about whichway to turn the allen axel head in the end of the left side fork ( i am known for breaking stuff ) it came right out and again thank you sir.
buell1965
Postby buell1965 » Fri Oct 23, 2020 2:17 am
Easy peasy , loose the allen pinch and counter clockwise on the 5/16 allen threaded axel . Thanks again dave
buell1965
