Master Cylinder
Master Cylinder
Postby Señor Willy » Sat Nov 14, 2020 7:46 am
Need a master cylinder for my mastiff.
Would this be up to the job I wonder or should I avoid?
Anything would be better than the one one the bike.
https://www.ebay.co.uk/itm/124382640976
Señor Willy
Re: Master Cylinder
Postby jpmsteadi » Sat Nov 14, 2020 8:29 am
Brake masters are pretty universal. I would just check your stock one to see if there is a size marking on it and try and get one that is the same. I would recommend a newer used brembo or nissin master, both are great. I imagine a 12.7mm or 13mm would be around the size for a single 4 piston caliper: that is what was on my Skorpion. I went to a 14mm brembo radial master off of a 2015 ducati multstrada and it made a huge difference in brake feel. I don't suggest that for a bike that going to be taken off road: having the integrated reservoir is good for crashes.
jpmsteadi
Re: Master Cylinder
Postby Señor Willy » Sat Nov 14, 2020 10:48 pm
jpmsteadi wrote:Brake masters are pretty universal. I would just check your stock one to see if there is a size marking on it and try and get one that is the same. I would recommend a newer used brembo or nissin master, both are great. I imagine a 12.7mm or 13mm would be around the size for a single 4 piston caliper: that is what was on my Skorpion. I went to a 14mm brembo radial master off of a 2015 ducati multstrada and it made a huge difference in brake feel. I don't suggest that for a bike that going to be taken off road: having the integrated reservoir is good for crashes.
Hi jpmsteadi.
I was going to buy this as I've seen it recommended on here before as a straight swap but it's. not available.
https://www.ost2rad.com/MZ-Spare-Parts/ ... --301.html
Señor Willy
Re: Master Cylinder
Postby jpmsteadi » Mon Nov 16, 2020 10:12 am
really just about any master should be pretty much plug and play. I don't know about mirror mounts or the like, but thats about the biggest thing that would be annoying. I would try something like this:
https://www.ebay.co.uk/itm/2017-14-17-K ... Sw1PpfUb2b
Or something of the like. 12-14mm axial brake master off something relatively modern, ideally something slightly nicer of a brand too (something like KTM is more likely to have nicer components than a low cost honda or yamaha. I would use the opportunity to upgrade to something really nice like a radial master off of a ducati or the like, but its possible that will make things harder in terms of fitting the remote reservoir or the like.
jpmsteadi
Re: Master Cylinder
Postby Señor Willy » Fri Nov 20, 2020 11:33 am
jpmsteadi wrote:really just about any master should be pretty much plug and play. I don't know about mirror mounts or the like, but thats about the biggest thing that would be annoying. I would try something like this:
Would the mz brake light wires plug straight into one of those?
Señor Willy
Re: Master Cylinder
Postby DAVID THOMPSON » Fri Nov 20, 2020 12:20 pm
kaw klr 650 and kymco scooters appear to use similar items
look at a duke in a ktm dealer shop
there is a switch on ktm unit may have to solder wires to its tabs or may just plug in
i will look at a duke sat morning a dealer an see
my traveller is using a Saxon tour(rotax) clutch cable with some odds and pieces
form BMW and a Cannondale lever to sort out my no clutch cable problem
if they made it it can be fixed
above does not apply to fords and Chevy
Re: Master Cylinder
Postby Señor Willy » Sat Nov 21, 2020 7:24 am
Just bought this one for KTM so hopefully works out.
Señor Willy
Re: Master Cylinder
Postby ralf » Sun Nov 22, 2020 2:23 pm
As generally stated on previous posts, just get one with the same diameter piston as the original and you can't go far wrong. Whenever I need a master cylinder I look on eBay for a Nissin, common on modern Japanese bikes. I know you can get new Chinese copies for nowt but a genuine second hand Nissin is a better option in my opinion, your life relies on it !! I've used used Nissin master cylinders on a Norton Commando renovation and to replace a MZ master cylinder on my 500R.
If anybody knows the difference between a master cylinder on an abs system and the same bike non abs then I would like to know.
Any master cylinder whisperers out there?
ralf
