JawasandMZs wrote:You've done TWO failed electronic ignition upgrades? Eh?
That's not very encouraging. I'm thinking of paying £240 for a full Vape upgrade.
thinking a bit more about the idea of connecting a LED on the ignition coil primary, that'll work fine for detecting the ignition timing. But when the engine runs, the opening of the points will create a more significant V, at the exit pole of the primary winding. And that will burn the LED. Maybe not if a more significant R is used, or a high voltage diode added, but then it might not work at low revs. Maybe not such a good idea.
I don't understand this either. Yes, when the coils supply is interrupted by the points there is a significant self induced voltage produced (Back EMF) but this is produced at the contact breaker side and is mostly absorbed by the capacitor (condenser) wired across the points. There will no voltage peaks at terminal 15, the main power input to the coil, as this is swamped by the very low impedance battery which it is connected to for its power. The voltage driving the LED or filament bulb will remain just as constant (12.5V -14.5v) as any other electrical device being driven by the bikes battery. Could you explain what you mean Puffs please?the opening of the points will create a more significant V, at the exit pole of the primary winding
