50:1 or 33:1
50:1 or 33:1
Postby Andy_C » Sat Jun 05, 2021 3:19 am
Seems to be some differing opinions regarding petrol / oil mix for the TS 250.
Seems that some swear by 33:1, others by the recommended 50:1 which is what I was planning to use.
In the last 40 years since the bike was made I am sure that oil technology has improved and a modern semi synth (which is what I used to use in my ETZ) will be just fine at 50:1
Any thoughts?
Andy_C
Re: 50:1 or 33:1
Postby Puffs » Sat Jun 05, 2021 5:30 am
Re: 50:1 or 33:1
Postby Andy_C » Sun Jun 06, 2021 2:05 pm
Yep - factory recommendation for the TS250/1 is 50:1 and I plan to use the same oil as I use iin my Kawasaki Triple, and as I think I said used to use in the ETZ.
Quite tempting to follow you and go for 40:1 just for peace of mind.
As you say modern Semi - Synth oils are pretty much smokless these days.
Andy_C
Re: 50:1 or 33:1
Postby Guesi » Sun Jun 06, 2021 11:58 pm
MZ recommended 1: 50 for the TS and ETZ Models.
So nowadays with the better 2-stroke oils than in the GDR 1:40 is far to much oil...
And as always: More is not always better :-)
Here in Germany many MZ drivers have rations with about 1:60 or 1:70 without any problems.
MZ allowed 1:100 using full synthetic oil (castrol biolube then)for the ETZ 250/251 .
Guesi Motorradteile
MZ spare parts
Re: 50:1 or 33:1
Postby Puffs » Mon Jun 07, 2021 2:45 am
Re: 50:1 or 33:1
Postby breakwellmz » Mon Jun 07, 2021 8:50 am
Too much oil makes it run weaker in terms of fuel/air, i thought someone of your vast knowledge would know that! :wink: :lol:
Re: 50:1 or 33:1
Postby Andy_C » Mon Jun 07, 2021 11:45 am
Guesi - I was thinking along those lines in that modern semi synth oils are way better that the oils of 40 years ago when these bikes were built.
I was thinking that perhaps going to 40:1 might give a little more protection, but if the ETZs are running at 50:1 that is what I'll stick with as I used to run my old ETZ pretty hard with no problems.
Andy_C
Re: 50:1 or 33:1
Postby Puffs » Tue Jun 08, 2021 5:04 am
Re: 50:1 or 33:1
Postby Blurredman » Wed Jun 09, 2021 2:48 am
breakwellmz wrote:Too much oil makes it run weaker in terms of fuel/air, i thought someone of your vast knowledge would know that! :wink: :lol:
Although that is true, I've now put 14k on one bike, and 18k on another and not re-jetted. I did the calculations at the time for 30:1 and the margin is so small it just doesn't matter.
Infact, the jets for the pre-mix vs injection etz 250's are the same. I know at a recommended 50:1 it's more in line with the pump, but alas the pump is directed straight into the barrel. In the official service manual, no distinction is made between the two.
1987 MZ ETZ300 - 40,000 miles
Re: 50:1 or 33:1
Postby Puffs » Wed Jun 09, 2021 4:03 am
