Puffs wrote:BM's website: see his signature in any of his posts, for instance https://mzriders.com/viewtopic.php?f=5&t=12002
You lock the plate with the 3 screws. On my ETZ I have a big O-ring around the adjusting plate #18, which is compressed when you tighten the 3 screws through the cover, and thus locks that adjustment plate #18 (as well as seals the lot for oil). I do not know how that is done on the ES.
Yes, on my ETZ I never had to use a chisel either. So just rotate it by hand.
Other than that: I never worked on an ES, and the ES is probably different from my ETZ; hopefully someone with ES experience chimes in.
parrbd wrote:Isn't Castrol R40 straight bean oil? I used to run that in my TZ350's premix at 20:1. I had not thought about using it in the gearbox. Let ud know how it works.
grimstone wrote:Puffs wrote:BM's website: see his signature in any of his posts, for instance https://mzriders.com/viewtopic.php?f=5&t=12002
It seems the same on ES. I think I may also need a new oring
Users browsing this forum: No registered users and 131 guests
