Puffs wrote:Hi Andy!
Hoping you'll get along well with your new found friend, manuals you may find on ftp://blurredmanswebsite.ddns.net/Vehic ... Documents/ or http://www.miraculis.de, and for spares see https://mzriders.com/viewtopic.php?f=5& ... 896#p47896
Do not forget to premix.
Any pics? Whereabouts are you?
AndyP66 wrote:And the choke is fitted to the handle bars. But appears to slide back to closed on its own
Gerryman Ts125 wrote:AndyP66 wrote:And the choke is fitted to the handle bars. But appears to slide back to closed on its own
Just slacken the screw holding the choke lever onto the handlebars, and either put grease or oil into the inside of lever where the cable comes in. Then retighten it to the handlebars and screw it in until it stays on. One more problem with the choke cable, is the little piston that operates the choke seizes or jams, causing the end of the cable to shear off. But I took mine apart and cleaned it off and replaced the end (with a brake cable end crimped onto the cable) and it worked great. One thing about Mz's is you can repair them simply.
Gerryman Ts125 wrote:If you require assistance, at least one (or more of the Avengers) will heed your call. Having a pdf of a Ts 125 does help, when one or more of us is lying in bed recovering from a night on the tiles. Just ask away. We're the fourth emergency service
AndyP66 wrote:Gerryman Ts125 wrote:If you require assistance, at least one (or more of the Avengers) will heed your call. Having a pdf of a Ts 125 does help, when one or more of us is lying in bed recovering from a night on the tiles. Just ask away. We're the fourth emergency service
Being new to the forum, I think I am lost in your terminology lol.
Might need to explain who the avengers are etc.
