New TS125 owner
New TS125 owner
Postby AndyP66 » Sun Oct 17, 2021 3:50 pm
Hi All
Thought I would introduce myself. I am ANDY 55 yr old vintage enthusiast, who loves all things old, mostly the 1940s.
Brought a 1979 TS125 last week. It’s my first bike as apart from a brief period 15yrs ago I haven’t ride a bike let alone a vintage one. I know very little about motorcycles so expect plenty of questions in the future, which I will apologise for now.
As I said the motorcycle is a 1979 TS125. Overall in good condition. But will be going through a colour change during the winter, which might go against some purists. But will explain in more detail later. At the motor the bike will start but does cut out even when warmed up. It appears that when I fully close the throttle the bike will not tick over , so any advise on the problem is appreciated.
AndyP66
Re: New TS125 owner
Postby Gerryman Ts125 » Sun Oct 17, 2021 6:05 pm
Hi Andy, welcome to our nightmare. Is your Ts 125 a lux or Alpine model?
The Alpine model, had no chrome on the side of the fuel tank. It never had a revolution counter, only a front light mounted speedometer
.Same rolling chassis and engine/brakes. A rear spindle fitted side stand, was also a optional extra.
Hope you find the carburator adjustment (on the O/s) along with the air petrol screw.
Unless your model had the tick over controled by throttle cable adjustment. But the carburator will only have the one adjustment screw.
You should be able to download a group of files (for a Ts 125) from this site, to assist you with your plight.
Gerryman Ts125
Re: New TS125 owner
Postby AndyP66 » Sun Oct 17, 2021 11:38 pm
Hi Gerryman.
I guess my is the Alpine model as it doesn’t have the chrome on the tank. Plus it has the headlight with the speedo mounted into it.
Not going to get much time to look at the bike again till the weekend. I have found the one adjustment screw on the left side of the carb and the choke is fitted to the handle bars. But appears to slide back to closed on its own
AndyP66
Re: New TS125 owner
Postby Puffs » Mon Oct 18, 2021 3:45 am
Re: New TS125 owner
Postby Blurredman » Mon Oct 18, 2021 6:10 am
Congratulations and welcome!
Re: New TS125 owner
Postby AndyP66 » Mon Oct 18, 2021 11:49 am
Puffs wrote:Hi Andy!
Hoping you'll get along well with your new found friend, manuals you may find on ftp://blurredmanswebsite.ddns.net/Vehic ... Documents/ or http://www.miraculis.de, and for spares see https://mzriders.com/viewtopic.php?f=5& ... 896#p47896
Do not forget to premix.
Any pics? Whereabouts are you?
Thanks for the links.
I live in a small town called Tamworth in Staffordshire in the U.K.
not figured out yet how to attach a picture.
AndyP66
Re: New TS125 owner
Postby Gerryman Ts125 » Mon Oct 18, 2021 12:15 pm
AndyP66 wrote:And the choke is fitted to the handle bars. But appears to slide back to closed on its own
Just slacken the screw holding the choke lever onto the handlebars, and either put grease or oil into the inside of lever where the cable comes in. Then retighten it to the handlebars and screw it in until it stays on. One more problem with the choke cable, is the little piston that operates the choke seizes or jams, causing the end of the cable to shear off. But I took mine apart and cleaned it off and replaced the end (with a brake cable end crimped onto the cable) and it worked great. One thing about Mz's is you can repair them simply.
Gerryman Ts125
Re: New TS125 owner
Postby AndyP66 » Mon Oct 18, 2021 1:46 pm
Thanks again for the guidance.
Got her started again tonight. But she is still cutting out when the throttle is fully closed. Tajen the battery off to make sure it’s fully charged. Is there adjustment for the throttle cable? If so would this solve the cut out issue when I close the hand throttle fully.
AndyP66
Re: New TS125 owner
Postby DAVID THOMPSON » Tue Oct 19, 2021 4:10 am
some bikes// not all set idle by leaving no free play
do pay attention to cable routing on all types so it does not give it more fuel in a turn
Re: New TS125 owner
Postby Puffs » Tue Oct 19, 2021 6:33 am
Re: New TS125 owner
Postby DAVID THOMPSON » Tue Oct 19, 2021 12:04 pm
my dealings with old BMW's when you got the mag and points correct..
most of your carb problems went way ..except for the brass float sinking
wine bottle cork to the rescue
Dave
Re: New TS125 owner
Postby AndyP66 » Tue Oct 19, 2021 2:59 pm
Thank you all that have responded to my posts. I really appreciate the advice.
I will need to read them all a few times to get my head around what I am being told. Sorry for this, but like I said I am new to motorcycle ownership. Hoping I can get it sorted as I don’t want to be put off the pleasure of owning a vintage bike so soon.
AndyP66
Re: New TS125 owner
Postby Gerryman Ts125 » Tue Oct 19, 2021 4:37 pm
If you require assistance, at least one (or more of the Avengers) will heed your call. Having a pdf of a Ts 125 does help, when one or more of us is lying in bed recovering from a night on the tiles. Just ask away. We're the fourth emergency service :-D
Gerryman Ts125
Re: New TS125 owner
Postby AndyP66 » Wed Oct 20, 2021 4:58 pm
Gerryman Ts125 wrote:If you require assistance, at least one (or more of the Avengers) will heed your call. Having a pdf of a Ts 125 does help, when one or more of us is lying in bed recovering from a night on the tiles. Just ask away. We're the fourth emergency service :-D
Being new to the forum, I think I am lost in your terminology lol.
Might need to explain who the avengers are etc.
AndyP66
Re: New TS125 owner
Postby Blurredman » Thu Oct 21, 2021 2:41 am
Surely not they don't need explaining..
https://www.youtube.com/watch?v=10QW3Az1FTw
Users browsing this forum: Bing [Bot] and 6 guests
