AndyP66 wrote: I decided to send it to a classic bike mechanic at the end of November. I explained the issue with the bike and said I just want it running right so I can ride it. Three weeks later I got it back, at a cost of just over £200. Only to find it’s running worse than before I handed it over.
Now lost the Will with it.
Jay Bee wrote:Andy -
I aplogise for being a bit hasty in my initial assessment of the situation. I fully agree with everything Puffs has said, however.
Let's hope your man sorts it.
Puffs wrote:Andy, you say "Anyone got any advice.", but advice about what?
About repairing the carb: I gave some advice, but you haven't actually told us what was broken. Well, you said "the mechanics broke the holding pin for the float", and that would be pin #19 in the drawing above; if that is the problem, a replacement pin would be easily found.
If it's one of the pillars, as I suspect, a repair as outlined may be possible, but it may not be successful on the long term.
About a replacement carb: an original BVF 22 N 1-3 carb will be hard to find. The new pattern (aftermarket) ones will probably be Chinese made (including probably the one JB linked to), but there is no reason why a bike shouldn't run equally well on that too. But you have to set it up right, which can be quite a bit of work. Settings may include the low speed (idle) circuit, the slide cut-out, the needle guide, the needle, the main jet, and the fuel level in the bowl. See the manuals for details.
About 22mm vs 24mm: if set up correctly, it should also run well with a 24mm carb. It might even be marginally quicker (& use more fuel). I say this because when I was a slightly younger boy, I competed in the 50cc MX class. On a 50cc Kreidler, with a 24mm Dell'Orto (as many used). Now if a 50cc 2T can run well on a 24mm carb, I can't see why a 125cc couldn't. Btw, 125 MX bikes of the day used 28 to 34mm carbs (a VM34SS on the YZ125, as I had later). So it is possible.
While a bigger carb might give slightly more top end, at low revs it may actually pull a little less, particularly at fully open throttle.
Anyway, for a TS125 I recommend to stay as close as possible to original, although fitting a 24mm carb shouldn't be a major issue. But it has to be set up properly, and standard settings for the original BVF carbs may not be applicable.
Setting up a carb entails riding by an experienced rider who judiciously tests the engine response, at various RPM ranges & throttle openings, and looking at the plug picture (plug chop). It can take a while.
Users browsing this forum: No registered users and 63 guests
