Baghira trouble - Any suggestions??
Postby dynamite » Wed Jun 14, 2006 3:00 pm
I recently bought a 2003 Baghira with 10,000 kms on the clock. I love the bike to bits but have noticed a bit of a problem with it.
When the engine is thoroughly warmed up, tickover is not as smooth as when cooler and more worryingly, if I wack open the throttle from tickover or just above the engine immediately cuts out, flooded I think and not start again until cool.
This does not happen in the first couple of miles, only when the engine is hot.
I thought it may have been the "straight through" race can I had on it but I put the original exhaust back on and it is still happening. As far as I know, everything else is standard.
Has anybody else experienced this? Any suggestions would be most welcome.
Thanks....
dynamite
running fowl
Postby DAVID THOMPSON » Wed Jun 14, 2006 7:51 pm
NGK DPR 8 EA - 9
http://www.mzriders.com/viewtopic.php?t=1090
http://www.mzriders.com/viewtopic.php?t=827
check to see if correct plug installed
and fuel to air mix set 5 turns out
others may have more info
Postby Blathian » Wed Jun 14, 2006 9:54 pm
5 turns out? i had a mechanic tell me that anything over 3.5 is close to falling out? plz advize
thanks
Blathian
post after post
Postby DAVID THOMPSON » Wed Jun 14, 2006 10:46 pm
Users browsing this forum: Google [Bot] and 30 guests
